Solved Invitation Code per Group
Itadakimasu
Hello guys,
it would be really great if it was possible to give an every person in a group an invite, as I see it for now its only possible to create a token that everyone in the group could use right ?
Kind regards
Itadakimasu
Solution
so i maybe got it wrong ? i thought that token can be used once by 1 user in the group or can everyone that is in the group use it once ?
The option is not very explicit indeed, by creating a token and putting 1 in the field all users of this group will be able to use this token only once.
CRUEL-MODZ
Hello guys,
Kind regards
Itadakimasu
You can create a token that can only be used once per user : Screenshot
Itadakimasu
Yes, but you will have to add all users manually right ? thats a high efford if you have more than ~ 10 members though
Itadakimasu
CRUEL-MODZ
Solution
