Implemented Invited by info move
leoterik
Registered
Registered
I would say move the invited by message to a other position like in the user about or on the top of the profil right beside the points stets on the user profil would be greate
example:
this WOULD BE AWSOME!
They'll tell you how to do this by modifying the template of the template so it won't be included in the addon.
Can you pls tell me how exactly it works to change it for me? i dont get it because i have the same code twice, once in "member_view" and once in "member_tooltip " from the addon ... and i cant even edit anything in there^^
Yes there is the same code to display this in the member tooltip and the member page, so I will create an addon that you can install to do this template modification. Did you want the same thing on both in the member tooltip and the member page?
booth would be awsome
I made you the addon, you just have to install it, and if you want to disable: Screenshot you will have to disable both template modifications : Screenshot
  • XenSoluce-InviteSystemInviteBy-2.0.0.zip
awsome works, can i disable the invites by on the old position ?
i guess disable member_wiev ?
