Implemented is compatible with Upgrade Coupon?
est3ban129
Predefined Tags
Required Custom Fields On Upgrade
Required Custom Fields On Forums
SEO Optimization
these two plugins are compatible with each other?
Can I use the duration and then apply coupons?
Thanks
For now no, but I want to make a system where you could select a duration and put a coupon that is, so that you can define a coupon by duration.
Then I'll wait for this system to work, thank you.
User Upgrade Duration is now compatible with Upgrade Coupon ! :)
