Support Removing previous upgrades with this add-on
irateAustin
Before I found this add-on, I had 1yr & 5yr membership options. Now that I can add a 5yr option to the original 1yr, I can turn off the 5yr option. Has anybody tested what this does with renewals? If I turn off an upgrade, can it still auto renew?
If you deactivate the duration, it will still work, but if you delete it, I'm not sure it will work.
