Solved Wrong Forum Meta-Title
SyTry
Reposting from MarkoRoots at XenForo :
Hi SyTry, I have seen that, setting the XF default board title (in a way) and also the board meta title in your plugin,
it add to the home page meta title, the meta title (of your addon) more the XF default board title at the end, so is visualized in this way:
Board Meta title of the plugin + XF default board title
So if the board meta title is just decided and wrote in a way, to your plugin, how can I remove the XF default board title from the end of the meta title created?
Yes obviously. I mean if I set the meta title of the board on your plugin, it should show only that. Instead to me, but maybe is a problem of my code, setting the meta tile of the board on your plugin, the real meta title that I see is a line composed of:
the meta title of your plugin and following the default tile of the board.
For example setting the meta title of the addon in this way: "Xenforo - The best comunity software online"
and the default XF board title as: "Xenforo"
my real meta title is shown in this way:
Xenforo - The best comunity software online - Xenforo
that is not good... So I would like to remove "Xenforo" at the end. But I have this problem only with the home page, the other links now are shown well.
MarkoRoots
SEO Optimization
Hi SyTry, any news on this? Remember that is a week that we have to make this fix, I have bought this plugin to make a better seo but this problem is creating seo problems as you can imagine. The Meta Title of the board as you now is the first thing and is foundamental.
SyTry
Hello, yes a fix is coming today. Sorry for the delay!
SyTry
Hello, this is now fixed in the 2.3.0 Fix 3 (coming today) !
Solution
MarkoRoots
SEO Optimization
Great SyTry, many thanks, Meta Title is too much important as you know and this is realy good also for the plugin.
I go to test it. Thanks again
SyTry
MarkoRoots
SEO Optimization
It seems that the it add from:
Basic options​
the Board title field,
to the one wrote in the addon as meta-title.
Instead to use only the one setted in the addon.
So I'm seeing this as tag h1 shown of my home page:
Name of the forum with some | Name of the forum
instead of:
as setted in the addon under board meta-title.
SyTry
I don't recall modifying the H1 only the TITLE, we'll have a look thanks for your report!
SyTry
Hi SyTry, some news to fix the problem?
Hello, for now I'm on vacation. I can share a fix for this but I don't have my computer with me. Another version is ready to be shared but with my other computer..
MarkoRoots
SEO Optimization
SyTry do you know when you come back from the vacation?
Just an indication to know if are few days or (as I hope for you) some month. :D
SyTry
Hey, I'm back. We'll make an update for this and the orther stuff ;)
So you also want the H1 to be modified ?
