Implemented xx invites per token
leoterik
Registered
Registered
would be nice to see soon that you can choose how much invites can be generated per token
so token xxxx can generate xx invite codes
This will be added ;)
awsome how long it takes?
This has already been added in the next update;) : Screenshot
maybe a next suggestion, remove the token stuff and instand instand add invite codes per group
and btw a question
if i give a usergroup a token and 200+ members are in this group
ANYONE can use the token to get one invite or ?
Delete tokens will not be possible because I will unfortunately be asked, but in the future I will see to create a system in the acp or the administrator will be able to create invitation codes or the latter can be used X times.
Normally, a token can be used once by members of a user group, but I saw that there was a bug, in the next update it will have a fix;)
pls make it that every token is unieqe so every user get a new one generated everything else dosnt make much sense.
I'll give you an example:
We have two groups: group A and group B.
Group A = 10 members
group B = 20 members
We generate a token for group A
This token can only be used once by members of this group.
It makes sense because otherwise a token can be used to register, or it won't have a code system;
I'm not if you actually understood a generic token can be used once all the members of a user group share once.
the token is not unique!
the code is unique
so: 1 generated token for every 10 members
so: member1 = 1 code, member2 = 1 code etc etc etc
so with 1 token generated all members of the group can use it once
Yes normally it was planned as that, but I saw that there was a bug in the next update it will have a fix;)
moreover it will add the system requires that tokens can be used X times per user;)
yes pls fast :D
+ can you add on the profil a info that the user got invited by
Yes this is also implemented ! (y)
Please, if you have any suggestion make one thread for one suggestion. This is much simple for us :cool:
