A affLIFT Licensed Licensed User Upgrade Pro Joined Feb 9, 2021 Messages 10 Reaction score 6 Mar 29, 2021 #1 I installed the add-on, setup the options, and made a test purchase. I'm not seeing receipts... Any idea why?
Solution CRUEL-MODZ Mar 30, 2021 Hello, To access the invoice go to invoice : user-upgrade-invoice/ Screenshot affLIFT said: The top menu is also not showing the active subscription. Only old expires ones: View attachment 1092 Click to expand... Probably because this button is not activated, to activate it go to: style property > [Xen-Soluce] User Upgrade Pro Screenshot Regards, CRUEL-MODZ
A affLIFT Licensed Licensed User Upgrade Pro Joined Feb 9, 2021 Messages 10 Reaction score 6 Mar 29, 2021 #2 The top menu is also not showing the active subscription. Only old expires ones: Upvote 0 Downvote
CRUEL-MODZ Administrator Staff member Administrator Moderator Licensed Joined Jul 8, 2019 Messages 1,167 Reaction score 669 Mar 30, 2021 #3 Hello, To access the invoice go to invoice : user-upgrade-invoice/ Screenshot affLIFT said: The top menu is also not showing the active subscription. Only old expires ones: View attachment 1092 Click to expand... Probably because this button is not activated, to activate it go to: style property > [Xen-Soluce] User Upgrade Pro Screenshot Regards, CRUEL-MODZ Upvote 1 Downvote Solution
CRUEL-MODZ Administrator Staff member Administrator Moderator Licensed Joined Jul 8, 2019 Messages 1,167 Reaction score 669 Apr 2, 2021 #4 Hello, Is your problem solved? Regards, CRUEL-MODZ ? Upvote 0 Downvote
A affLIFT Licensed Licensed User Upgrade Pro Joined Feb 9, 2021 Messages 10 Reaction score 6 Apr 2, 2021 #5 CRUEL-MODZ said: Hello, Is your problem solved? Regards, CRUEL-MODZ ? Click to expand... Yes, that solved the issue Upvote 0 Downvote
CRUEL-MODZ Administrator Staff member Administrator Moderator Licensed Joined Jul 8, 2019 Messages 1,167 Reaction score 669 Apr 2, 2021 #6 Hello, affLIFT said: Yes, that solved the issue Click to expand... Thank you for your quick response! Are you happy with the addon? Regards, CRUEL-MODZ Upvote 0 Downvote
A affLIFT Licensed Licensed User Upgrade Pro Joined Feb 9, 2021 Messages 10 Reaction score 6 Apr 2, 2021 #7 CRUEL-MODZ said: Hello, Thank you for your quick response! Are you happy with the addon? Regards, CRUEL-MODZ Click to expand... Yes, but I just posted another suggestion Upvote 0 Downvote
F fionix Licensed Licensed User Upgrade Pro Joined Oct 12, 2021 Messages 1 Reaction score 0 Oct 12, 2021 #8 For some reason the list of Invoices do not show up on our forum. I followed the above instructions but nothing appears there. Shall I send a support ticket? Upvote 0 Downvote
SyTry Administrator Staff member Administrator Moderator Licensed Joined Jul 8, 2019 Messages 593 Reaction score 367 Oct 12, 2021 #9 Hello, tagging CRUEL-MODZ for this Regards, SyTry Upvote 0 Downvote
