Solved Tested on 2.2 and it's not working (Solved: Works fine on 2.2)
Darklol
Required Custom Fields On Upgrade
Hi,
Just purchased and tested the addon on 2.2, I'm sorry to say it doesn't work.
I was able to purchase an upgrade with blank required fields and when going into required for upgrade it doesn't display the fields only the notice:
Merci :)
Hello
All our addons will be updated for XF2.2 in a short time.
We're sorry for the inconvenience.
Can you pass me the link to your site so I can see the problem?
It's totally my bad, it works but please correct me if I am wrong.
To make it work, we need to set the Display Location to Required to upgrade and check the Require for user upgrades in General Options for the specific field. Is that correct ?
What was happening I was only using the checkbox option Require for user upgrades under General Options.
Merci encore et désolé si j'ai interprêté.
Oui québecois à Montréal :)
Vraiment désolé, je confirme que ça marche super bien sur 2.2 sans aucun problème.
