Solved Problems with the topic prefix
Motuzko
Registered
Registered
Custom Prefixes & Banners
DM Auto Reply
Good afternoon. XenForo® v2.2.16 Addon: Custom Prefixes & Banners 2.1.0 Fix 4The banners are working , but the prefixes are not , there are no errors .
I looked through the forum, your client has the same problem when using the Multi Prefix Addon, if necessary, I can provide it to you for testing.
Hello there,
Yes you can give me a version of the addon in private message, I'll see what I can do.
I'll look into it if, I can tomorrow
