Solved [Xen-Soluce] Ban System for Dispute is not working for me
raiden
SEO Optimization
I installed my addon on username.gg, tried purchasing from paypal and refunded and it didnt work as said.
Solution
Here is a new version that should correct your problem, it might be better to uninstall the old version and then install this new version :)
This is a cron job that bans users who refunded
Maybe it's time for the cron job to run ^^.
you can test by forcing the execution of this cron job (it's called : Ban System for Dispute)
oh Im very new to xenforo, Is there any guides to install the cron job thingie?
its not an admin user, Plus when it happened the user only was removed from upgrade
not banned
i only installed the addon from Xenforo, should i do it manually too?
if you want to access my website to check it yourself i can give you access to it, its username.gg
okay thank you, if you want my discord for further updates lmk, I might also hire you for some custom addons if your down.
Solution
