Add-on [Xen-Soluce] Custom Prefixes & Banners 2.2.2 Fix 1
This add-on allows you to customize your prefixes and your banners.
Overview Feature list Copyright info Releases (17) Reviews (3)
SyTry
A new update is available for [Xen-Soluce] Custom Prefixes & Banners by SyTry.
Update highlights​
Note :
- Bug fixes :
  • Another compatibility issue with the MultiPrefix addon (Motuzko #Report)
- Note :
  • This fix is also available for XenForo 2.2 (Addon version: 2.1.0 Fix 6).
Complete Change Log​
Note :
- Bug fixes :
- Note :
Read more about this product...
Hello
I would like to buy this module but I want to understand, if I buy the module for 3 months after the 3 months it will no longer work? or it will work but I will not have the updates
It's like xenforo, once your subscription is over you can continue to use it but you won't get the updates, the support...
does it work for xfv2.2.12 version?
And to conclude the purchase, I have this error
I just made a purchase for this addon
Payment is on stripe
Hello I just purchased and installed this addon but it doesn't seem to work.
the effects are not applied on Xenforo 2.3.7 with the Multi Prefix addon
Works when i desactivate multi prefix addon.
Thanks for your help
Okay, I'll look into that. Can you send me the add-on (Multi Prefix) in a private message?
Product Information
Compatible XF 2.x versions
  1. 2.2
  2. 2.3
Required version of PHP
  1. PHP 8.0+
Seller
SyTry
Release date
Last update
Customer rating
5.00 star(s) 3 ratings
Pricing information
3 Months
€7.00
Renewal cost
€5.25
6 Months
€12.00
Renewal cost
€9.00
12 Months
€18.00
Renewal cost
€13.50
Lifetime
€36.00
