Solved error in question nodes
est3ban129
Predefined Tags
Required Custom Fields On Upgrade
Required Custom Fields On Forums
SEO Optimization
i have this error when forum type is Question and can't create nodes..
Solution
I can't reproduce your problem, working good for us. Can you look in your DataBase and let us know if you have a column xs_pt_tags_node in your xf_node table ?
SyTry
Solution
est3ban129
Predefined Tags
SEO Optimization
thank you very much, it seems that the error I had has been solved with 2.2.0 fix1
