Suggestion Load avatar once
Free add-ons
Avatar Gallery
Jorge
Registered
Registered
I installed the addon in my local host for testing. Before using on server .
I have less space on my webhosting
So my question .it is possible to load avatar from only from avatar gallery .
Example-
After uploading image from avatar gallery .the avatar copied to internal path. It's used space .so it's possible only use single image from avatar gallery
Thankew
