Solved Invite error
leoterik
Registered
Registered
I get this error if someone wanna singup with the invite: https://prnt.sc/qbjous
no i dont use right now your invite addon but it cause the error and its not even installed
do i need to remove the database fields manuell ?
Yes, sorry, I obviously have to add a line to delete the column: xs_is_count in xf_user.
Thank you, fixed in the 2.1.5 Fix 2 version ! ;)
