Implemented possibility of generating more than one token
est3ban129
Predefined Tags
Required Custom Fields On Upgrade
Required Custom Fields On Forums
SEO Optimization
I currently have 3 types of Token.
2 for administrators and 1 for registered users.
In the case of administrators only 1 token appears to generate.
How can I generate invitations with the second token?
It would be good to add a list with the available tokens and a small legend to reference each one of them
CRUEL-MODZ
I may have misunderstood the suggestion, because currently you can generate more than one invitation code with the same token, you just can't select the token.​
For the moment I've added this: Screenshot.
est3ban129
Predefined Tags
SEO Optimization
That right there in the picture is perfect.
a legend is missing to differentiate which token
CRUEL-MODZ
What do you want as a legend?
est3ban129
Predefined Tags
SEO Optimization
Name of tokens for example
CRUEL-MODZ
It's going to be too much information ^^, otherwise I just put the title, right?
est3ban129
Predefined Tags
SEO Optimization
CRUEL-MODZ
Just like that: Screenshot ?
And when there's only one token I also put the title or I put the token? Screenshot
est3ban129
Predefined Tags
SEO Optimization
it would be that simple.
When there is one, it is automatically selected.
CRUEL-MODZ
Yes, when there's only one, it's directly selected.
