Support Sitemap.xml not being Updated properly,Manual meta robot tag marked as "indexed" not appearing
perecm
SEO Optimization
Gmorning, I've discovered an Issue about the Sitemap generation and this addon:
I've created for certain Node -> Advanced Options -> Search Engine Index Criteria: Thread has at least X replies AND Thread was replied to no more than X days ago as follow:
I've added a Manual "Index / follow " to certain threads under this node for some Quality content Threads I want to maintain indexed:
Checking our current sitemap.xml files, those Manual Threads under this Node aren't being included... could you please give us a solution?. Could someone else confirm you're getting the same issue?.we're running XF 2.2 and the latest Xensoluce SEO 2.3.0 Fix 3.
SyTry
Hello, do you still have this issue? I though that it was fixed in the 2.5.0 version ?
