Implemented Edit avatar and Mood icon
Sadiq6210
User Moods Manager
Required Custom Fields On Upgrade
Change Type Resource
I noticed that I cannot click on the Mood icon and when I click on it, then I get (Edit avatar) window.
Shouldn't we get the moods chooser window when we click on the icon?
This is how it works in XF1 addon.
SyTry
Not at the moment. I will move your thread to the suggestion forum. I will implement it later, thank you ! (y)
Sadiq6210
User Moods Manager
As we just bought the addon and we will install it soon, is there any chance to get this implemented? :)
It is not practical to move to different page to select the mood, instead, the user should be able to select/change the mood quickly by clicking on the mood icon anywhere and change the mood in the same page (AJAX). Also, there should be an option to remove/clear the mood.
SyTry
Yes I will implement it in the next update, with that one :
For now I'm working on it ! (y)
CRUEL-MODZ
It takes a little while because we're not a little overloaded, but as soon as we can we'll release the update;)
Sorry for the inconvenience.
Sadiq6210
User Moods Manager
Thanks bro
I was looking for this thread today to see if there is any update.
We did not install the add on in our forum as we are waiting for this to be implemented, wish we can get it soon :) Thanks
CRUEL-MODZ
It's coming :
SyTry
Implemented in the next version : 2.1.2. Coming soon ! :)
