Support Questions/Confused
xomb
User Moods Manager
I just purchased the mood manager. Adding moods individually can be tedious, but I am okay with it.
However, here are the issues I'm having:
  • Is there a way for usergroups to see moods but not be able to use them?
  • On mobile, the mood is in an awkward position. Is there some way to move it?
  • Images/moods don't seem to resize very much. Is there a way to resize images to a smaller size automatically? Otherwise, if we choose to use emojis, they are just large.
  • There is no way to select no mood. When the mood is selected again and saved, it gives an error.
If you say no to this permission:
The user won't be able to select moods, but he'll be able to see other people's moods.
It's true that the name of this authorization is confusing :/.
So no, but where do you want it? I can do an update for that.
I can create an option when creating a mood so you can say the maximum size you want, and I can create a style property where you can say a default size.
Indeed there is no way to deselect it I have to create a permission to give this possibility
