Solved Problem with rebuilding posts event
The transactions created for posts event get removed automatically if you repeat the rebuild process.
Steps to reproduce:
  1. Create a post
  2. Run rebuild for posts event
  3. A new item will be inserted in xf_xs_cs_credits_transaction table
  4. Rebuild posts event again
  5. The item created in step 3 will be deleted
I had the problem but with Reply, I corrected the problem for reply, it will be corrected in the next update.
